810 plow - F.I.T.
Tom in Mo.
04-06-2005 05:53:38
I added some plow photos to the Gallery/Implement photos section on the left. If you need a closeup of a part,let me know. Note that the level adjusting lever is missing. It was snapped off at the crossmember and needs to be replaced.
F-I-T
04-06-2005 09:46:48
 Re: 810 plow - F.I.T. in reply to Tom in Mo., 04-06-2005 05:53:38
Thanks, Tom.
Would it be possible some time to see it directly from the rear and on the ground? If you ever have it dismounted, maybe a shot directly from the front as well.
Thanks again!
Frank
Tom in Mo.
04-06-2005 16:40:28
 Re: 810 plow - F.I.T. in reply to F-I-T, 04-06-2005 09:46:48
No problem. I used the Case 830 to move it from the garage as it is the only tractor I have available with the Cat. II lower lift links.
