420 W Brake Lever Question?
Henry J
04-05-2005 07:15:58
This concerns the difference between AM1859T and AM3064T which are the listed brake levers for the left side of a 420/430 with remote. The AM 1850T is for without remote and the AM3064T is for a tractor with a remote valve.
I have the ones for without remote but have added a remote while in the process of restoration. I have been told that the levers are the same except that the one on the remote has a particular bend in the shaft.
Can anyone shed some light on this issue. I hate to continue my search for the one to use with the remote and if and when I get it in find that is the same as what I have but only with a bend in it.
Thanx
Bguy
04-05-2005 18:42:03
 Re: 420 W Brake Lever Question? in reply to Henry J, 04-05-2005 07:15:58
third party image
Here is a pic of the left hand brake lever on my 420W with factory remotes. It is the same length as the right hand side handle , approx. 12" long. It does have a slight outward bend to clear the remote valve body. I also checked the one on my 435 with factory remotes and it appears to be identical. Hope this helps. (I also hope th pic link works!)
Dave - Ia
04-05-2005 17:18:28
I would also be interested in knowing what the brake lever looks like. My 430 has the remote hydraulic valve and the brake lever is missing on that side, I did purchase a lever for one without hydraulic valves and I am going to put it on sometime. It would be nice to know what they look like.
Henry J
04-05-2005 18:41:26
 Re: 420 W Brake Lever Question? in reply to Dave - Ia, 04-05-2005 17:18:28
Dave
I am guessing that you already know but just checking concerning the Bracket (I can't think of the correct name for the ranafranz just now) that the lever goes thru as a guide. It is different also on the left side. It took me forever to get my hands on one.
Bguy
04-05-2005 09:11:06
I can take a pic of a 420 with factory remotes tonight for you. I think it just bent out a little but it may be longer also.
Henry J
04-05-2005 09:26:45
 Re: 420 W Brake Lever Question? in reply to Bguy, 04-05-2005 09:11:06
Thanks BGuy - Looking forward to it
If you want to email it my address is [email protected]
Raymond Bagwell
04-06-2005 21:11:47
 Re: 420 W Brake Lever Question? in reply to Henry J, 04-05-2005 09:26:45
Go to www.mcataec.com and look under User Photo Gallery. Just Because section there is a picture of the bracket there.
