HERE IS AN EXCERPT FROM MY NEW BOOK DUE OUT SOON ENTITLED -- [A JOHN DEERE "H" RESTORATION GUIDE]: OBSERVATIONS: Not all Service Manuals provide the correct float adjust data. And if your carburetor is already installed, and you want to check both float level and needle valve seating, remove the fuel drain cock and install a brass fitting with a 1/4" clear hose attached. Then hold the hose up along side the carburetor bowl and turn the fuel on. This will show you the fuel level inside the bowl (float adjustment). This test apparatus can also show you if the needle seat is holding. If the needle seat is not holding, the fuel will come up to the bowl level, stop and then creep up until it runs into the engine. This test tube assembly is available from Robert's Carb all made up with instructions at low cost. Call (712) 262-5311, or go to -- www.robertscarbrepair.com If you want to do a quick and easy check, measure the fuel in the carburetor bowl. To do so, ensure that the drain cock is closed. Then open the fuel valve; allow one full minute for fuel to flow into the carburetor and then close the fuel valve. Have a measure ready to collect fuel from bowl. Open the drain cock and allow the bowl contents to flow into the measure. You should collect between 1/2 and 3/5 of a cup (from 4 to 5 ounces) of fuel! Failure could be either float level adjustment or a bad needle valve! Too little points to float adjustment, too much points to needle seat or both. For more, drop me a line -- [email protected]
