4020 lacks power
toby
04-05-2005 04:47:49
I bought a 67 4020D that starts and runs excellent. It does lack the power that it should have. I guess the first thing is to change filters and service the air cleaner (oil bath). I doubt that it lacks compression as it starts easy even in cold weather. Do you think the pump and injectors could be the problem or the transfer pump. Also I notice the fuel line from the tank has a rubber splice in it.
TOby
Glen Anderson
04-06-2005 07:13:52
 Re: 4020 lacks power in reply to toby, 04-05-2005 04:47:49
Like G/MAN said, check the simplest things first. I've found in the past it's best to start by checking inlet/intake restriction, exhaust backpressure, fuel transfer pump pressure, and injection pump timing when trying to diagnose engine power problems.
G/MAN
04-05-2005 13:39:12
Depending on the year of your 4020, it might have an adapter on top of the air-cleaner assembly where the vertical air pipe is mounted. There is a screen in that adapter. I've heard of those being badly plugged, and foiling all attempts to repair low-power complaints. If the air can't actually get inside the air cleaner itself, how clean the cleaner is won't make much difference. Think simple things first before diving into the fuel $ystem.
Gerald J.
04-05-2005 10:10:37
You can check the effect of the transfer pump by checking power with the fuel tank full and nearly empty. My gas quit running last spring with a quarter tank. A new transfer pump fixed that. It was just worn, wasn't broken.
Then I hear there are possible injection pump problems.
Gerald J.
Hayfarmer
04-05-2005 07:36:03
I think you are on the right track with filters and all to make sure that part is right. May be pump timing also and as mentioned return line must be open. If pump is defective you may find small black pieces in it the pump may be disintigrating. If the fuel line splice is sucking air it would be a problem.
JD@ Antique Acres
04-05-2005 07:17:45
I had a simlar problem afew years ago on my 4020
Changed the pump. Then the injectors. Then found that the return fuel line to the tank was partially blocked. Cleaned it and it run like new.
Mike M
04-05-2005 06:07:18
Did you put it on a dyno ? That's the only way you can know for sure how much power it has,and check for blow by at the same time.
toby
04-05-2005 20:20:14
 Re: 4020 lacks power in reply to Mike M, 04-05-2005 06:07:18
I did not dyno but it is turning about 70hp as I compare to our other tractors. It does run and drive great. I had rather drive it than my 7200. I wish they would make them again.
Toby
hogman_2002
04-05-2005 20:30:26
 Re: 4020 lacks power in reply to toby, 04-05-2005 20:20:14
Does the motor smoke any? If it smokes blue/whitish it could be a problem with the injection pump not being timed right.
