Can't get block off 720lp/piston stuck in block
Ben.So.Tex
04-04-2005 18:25:06
I got the journal caps off the crank. Got the block unbolted. Beat block with a wooden block and hammer and it won't budge. So what's the trick to getting it off? Ben
ChuckW
04-05-2005 07:38:30
 Re: Can't get block off 720lp/piston stuck in bloc in reply to Ben.So.Tex, 04-04-2005 18:25:06
you forgot to remove the bottom bolts...have fought some of these and failed to remember the frame bolts....but better take the oil line loose or you'll trash that item and is hard to get to. With all the block bolts loose the weight of the block will almost pull itself loose....
THANK'S FOR OIL LINE INFO
04-05-2005 08:56:59
 Re: Can't get block off 720lp/piston stuck in bloc in reply to ChuckW, 04-05-2005 07:38:30
Thanks I would have trash the line..Ben
Mike M
04-05-2005 11:58:07
 Re: Can't get block off 720lp/piston stuck in bloc in reply to THANK'S FOR OIL LINE INFO, 04-05-2005 08:56:59
The oil lines on that 720 should go to the main case casting and not directly to the back of the block. The block is drilled for an oil passage and the gasket seals the joint. Your rods may catch on them though. The model H and around 1941 to 1947 A's and B's are the oil line culprits.
JDBert
04-05-2005 06:26:26
Theres also a oil line attached if a 720 is the same as previous models. Its at the bottom of the block, inside the crank case, between the jugs. Takes a 9/16 wrench to get it.
Will P
04-04-2005 21:01:29
While I have never worked on anything other than an A, B or G. How I get the blocks out is.... With the head off, put a pry bar in-between the bottom of the block and the top of the frame. Pry the front of the block up. It breaks the seal of the block to the case. Don't pry too high. Just enough to break the seal.
Don't know if it works on the number series. But it worked on my 4 letter series tractors.
Good luck and let me know if it worked. One day I will have a 730 :-)
Will P
Mike M
04-04-2005 19:07:15
You may of left some bolts still in it going straight up in from the bottom through the frame.
Ben.So.Tex
04-04-2005 19:14:41
 Re: Can't get block off 720lp/piston stuck in bloc in reply to Mike M, 04-04-2005 19:07:15
I will recheck it tommorrow to see if their are any going stright up. I took 8 nuts off..Thanks. Ben..... ...
xragman
04-04-2005 18:59:24
R U sure U got all bolts out? then more power needed. dynamint maybe? BFH should do it.
