3010 pto
twopop
04-04-2005 18:22:59
I have read discussions in the past about drilling a hole in the pto housing in order to change the 540 shift pin w/o splitting the tractor.can someone supply the dimensions and location and size of hole
TIA
MSM
04-05-2005 04:39:46
 Re: 3010 pto in reply to twopop, 04-04-2005 18:22:59
Can't be done. You must split the tractor to repair the bent/broken pin.The pin is in the foward section of the rear end housing,not at the rear by the pto.
Tx Jim
04-05-2005 04:58:44
 Re: hole in reply to MSM, 04-05-2005 04:39:46
MSM,I read the post before you replied and I was trying to decide just where this hole could be drilled.After reading your reply I can stop scratching my head.It would have been nice if JD had put a couple of access plates to change pins without having to split tractor.If I owned a 3010/4010 I would eliminate the 1000 rpm option on pto and solve the little pin problem.Jim
