model differences 830-1020-2040
mark
04-04-2005 14:26:16
Gents,
Would some of you fellers that bleed green, give me a short lesson on the differences in these similar sized JD's? The pros and cons of each one and approximate HP's. All I have seen are 3 cyl. diesels.
Tx Jim
04-05-2005 05:13:52
 Re: model differences 830-1020-2040 in reply to mark, 04-04-2005 14:26:16
Mark,all above are 3 cyl.830D-35hp-open center hyd.,1020D/G-38 hp-closed center,2040D-40hp-early model open center/late model closed center.All good utility tractors.I don't remember any major problems.Jim
TG
04-15-2005 15:39:54
 Open or Closed Center - which is preferable in reply to Tx Jim, 04-05-2005 05:13:52
For a beginner, is there a brief explanation why one is better than the other?
Thanks
mark
04-05-2005 09:46:52
 Re: model differences 830-1020-2040 in reply to Tx Jim, 04-05-2005 05:13:52
what is the difference in open and closed center hydraulics?
Tx Jim
04-06-2005 04:06:25
 Hyd. differences open/closed in reply to mark, 04-05-2005 09:46:52
Mark,open center-pump circulates oil all the time,closed- center builds up pressure in line to a set psi(2250),pump continues to turn but does not circulate(pump) oil till a function is used that drops pressure,then pump starts pumping.HTH Jim
