D Cylinder Head Installation
JGC
04-04-2005 13:49:19
I am re-installing the head on my tractor.
Need some advice.
1. Do you coat the head gasket with sealer or install it dry?
2. One lead washer or two lead washers under each nut?
3. What do you seal the stud threads with so that coolant doesn't leak along the threads.
4. I&T says 208 Ft/Lbs torque. Is that correct.
5. Is there any way to re-torque without taking the rad and tappet case back off.
Bob-Wyo
04-04-2005 19:05:31
 Re: D Cylinder Head Installation in reply to JGC, 04-04-2005 13:49:19
Need some advice.
1. Do you coat the head gasket with sealer or install it dry? I USE COPPER COAT, BUT NOT ON FIRE RING. GASKET GOES SMOOTH SIDE TO BLOCK
2. One lead washer or two lead washers under each nut? ONLY 1 TO EACH STUD
3. What do you seal the stud threads with so that coolant doesn't leak along the threads.THE LEAD WASHER WILL DO THAT.
4. I&T says 208 Ft/Lbs torque. Is that correct. YES- WORK FROM CENTER OUT
5. Is there any way to re-torque without taking the rad and tappet case back off. AFRAID NOT.
