Curses! Am I in the wrong now?
Specter
04-04-2005 12:14:28
I was curious whether my John Deere AW was actually an authentic one. I guess not. The rear axle casting # was A3270R. Could somebody please confirm whether or not my tractor rolled off the factory as a tricycle front (in which case, the wide front was added after)? The serial number is 701469.
For the past few months that I've had it, I've always called it an AW. Was I in the wrong, and would I be in the wrong by continuing to call it an AW?
Lyndon
hardscrabble
04-04-2005 17:14:28
 Re: Curses! Am I in the wrong now? in reply to Specter, 04-04-2005 12:14:28
I have a 1949 A "wide front" which I thought was an AW but have been told different. It has 38" wheels, but where do I measure the front spindles to determine which axle I have?
CLW
04-04-2005 15:52:54
CMB is correct. The A3270R is used on the regular A. The 3271R was used only on the AN and AW. Sounds like you have the adjustable front axle with 17 3/4 in. spindles. The AW had 19 3/4 in. spindles. None of this means you can't still love your A. I think the proper way to discribe your tractor is that it is an "A with an adjustable front axle".
CLW
CMB
04-04-2005 13:37:02
From the serial # your "A" appears to be a '52. In that case, if it is a "row crop" "A" it would have a square axle housing. ALL late styled "AW"&"AN" tractors had a longer axle housing with round "Quills",& longer axles(I can't seem to lay my hands on the reference material right now, or I'd give you the part# for the long housing). Most also had 42" rear wheels, but 38" was optional. To further confuse things, there were two wide front ends-the one for the "AW" had "knees"& spindles 2" taller than ones used on a regular "A" equipped with a wide front! There is also a difference in the drawbar frame. Just because an "A" has a wide front doesn't necessarily mean it's an "AW". Some will say that the taller style is an "AWH", however John Deere discontinued using that designation when the late styled(pressed frame)tractors were introduced in 1947. This change(in designation) has caused much confusion over the years.
G/MAN
04-04-2005 13:35:43
105Diesel is correct about the interchangeability of the split-pedestal tractors. I believe all of the various front-end assemblies could be ordered as wholegoods. So you could just about have a different frontend for any day of the week.
105Diesel
04-04-2005 13:14:12
There's no way to tell what front end your tractor left the factory with---but beginning with serial number 648330, Model "A" Tractors could be ordered with the two-piece steering pedestal and a choice of front end equipment. Sounds to me like what you have is a Model "A" with an adjustable front axle, which is not the same as an "AW".
