Tugboat, it's not that easy on a used 2-cylinder tractor.. Well actually it is but not as it seems... ~The problem is: on those old worn 2-cylinder tractors the crankshaft wears out-of-round. So any attempt to use something like Plasti-Gage to set bearing clearances usually results in a tight bearing.. ~Probably the easiest way to set those bearings correctly is to remove the spark plugs, make sure the cylinders are well lubricated, then loosen one rod bearing & turn the crankshaft, once you get a base feel for the resistance start removing shims from the side you didn�t loosen, keep turning the crankshaft & removing shims until you feel a pronounced resistance to turning the crankshaft.. When you feel the turning resistance increase then install a .003� shim on each side of that rod & tighten. Then turn the crankshaft & feel for resistance.. Once one side is set, loosen that side & do the same for the other.. ~The above is the safe way as that accounts for the egg shaped crank journals & you end up setting the clearance to the tight point on the crank journal..[a must to avoid tight bearings].. ~If the cylinder is clean of carbon at the top of the bore & there isn�t a big ridge at the top you will get an even better feel for the crankshaft turning tightness if you remove the rod cap from the rod you aren�t working on & push it forward & lower the rod big end so you can turn the crankshaft without that rod & piston dragging.. Any questions just post back or E-Mail.. [email protected]
