720 wiring diagram
Russell Montgom
04-04-2005 10:08:38
I am working on a 720 gas and when i turn the ignition to ignition the coil is dead, when i turn it to lights the coil is hot. One more turn and the coil is dead again. I am needing a wiring diagram. The 720 has a resister on it the bottom connection has a wire from the small post on the starter that goes to it and the other line is one that goes to the coil. The other side of the resister goes to the ignition switch with the two headlights attached to it. We bought this 720 from a guy that had done some of the wiring. Thanks for the help Russell
Kevin L.
04-04-2005 12:38:20
 Re: 720 wiring diagram in reply to Russell Montgomery, 04-04-2005 10:08:38
If someone has changed the switch hope they have not replaced it with one from a 720D with pony start, it's ign. is only hot in the first click and dead in all the light setting. It would also have the resistor near the top edge of the swtich under the dash. Can not tell if the ign switch in the same on the 720D electric start. A good picture of the switch should be in the parts manual.
John T
04-04-2005 12:20:49
Russel, if you placed a test lamp on the ignition switches terminals, you ought to find one maybe labeled IGN or else its the one that will lite the lamp on the very FIRST turn position and stay lit as you advance the switch further. The terminals that get hot in the later/after turned switch positions are for like Lights Back and Dim or something like that, I forget. The terminal that turns hot on the very first switch position and stays hot is the one that should feed the ignition coil via that series ballast resistor. Sounds like maybe the coil and ballast feed is simply on the wrong switch terminal or maybe the switch is bad so they wired the coil in with the light switch feeds??
Lemme know
John T
JD hauler
04-05-2005 22:25:49
 Re: 720 wiring diagram in reply to John T, 04-04-2005 12:20:49
Most likely the wrong switch or bad switch, why not just wire it without the resistor, I have done several number series and have never had any problems, they start good, mostly without the choke even, I saw a guy at a show have a bad experience with a resistor and that made up my mind I would not have them on my tractors, just use a good 12volt coil with internal resistance.
Russell Mongtomery
04-04-2005 10:11:16
My email is [email protected] thanks for the help
