JD 4430 starting problems!
C. M.
04-04-2005 09:33:10
Just bought a 1974 JD 4430. Less than a 1000hrs on OH. Has trouble starting when it is cold. Starts good when it is warm and runs good. Is this normal on this model? The 4440 & 4240 that I have been around start a lot better.
Tx Jim
04-05-2005 04:35:17
 Re: aneroid rack in reply to C. M., 04-04-2005 09:33:10
CM,hard starting can be caused by aneroid on inj.pump not reseting.Try resetting throttle after shutting down engine while it's still warm.After shutdown push throttle fully forward,then back to idle.This should set rack in pump to start position.Also if the aneroid is mechanical you can trip it by hand.Ji
hogman_2002
04-04-2005 20:50:21
 Re: JD 4430 starting problems! in reply to C. M., 04-04-2005 09:33:10
Your timing could be off.
G/MAN
04-04-2005 10:30:37
The problem could be related to engine cranking speed, the fuel system or low compression due to valves that weren't brought up to the proper protrusion spec, if the head was serviced at all during the overhaul. Sunken valves drop the compression ratio and can lead to hard starting.
