70 L.P freezing up
shotgun
04-04-2005 08:20:13
Runs good till you put heavy load on it and it will freeze up from valve all way to vapizer.
Ben.So.Tex
04-04-2005 18:30:31
 Re: 70 L.P freezing up in reply to shotgun, 04-04-2005 08:20:13
Have you tried running it on vapor only? I run my 720 and 730 on vapor and they run fine for me. they don't freeze up for me. Good luck Ben..... .
buckeye al
04-04-2005 14:34:22
Where the frost begins is where the pressure drop is taking place!
If you have frost from the liquid valve to the vaporizer then the pressure is low in the liquid line ahead of the vaporizer and the liquid LP is boiling before it gets to the vaporizer.
It therefore sounds like a restriction in the liquid delivery line.
May be something is lodged in the line connections, collapsed or even something in the liquid line valve port/passageway.
Be careful & let us know what you find.
shotgun
04-04-2005 10:32:43
I have got it on Liquid and the water is hot that is running thru the vaporizer
Jake
04-04-2005 20:29:33
 Re: 70 L.P freezing up in reply to shotgun, 04-04-2005 10:32:43
Be sure the liquid valve is FULLY open. Or there is something stuck in the valve restricting it. Do you have the vapor and liquid valves mixed up? You should be running on liquid after the engine warms up. The LP then becomes vapor at the vaporizer where the hot water runs through.
buickanddeere
04-04-2005 08:41:14
Running on liquid or vapour? Any hot water running through the vapourizer?
