60 Runs bad
JDMAN60
04-04-2005 03:22:56
Well I think I found my trouble last night the points were badly fouled and corroded so I filed them nice and shiny and put them back in. Then old John started right up and ran good for about 2 minutes before it started missing and sputtering again, so I checked the points again and they are burned again. I put a hot coil on this tractor in anticipation of maybe electronic ignition some day, so now I think it is going to have to be today or will it help to put a resistor in the line?
buickanddeere
04-04-2005 05:28:52
 Re: 60 Runs bad in reply to JDMAN60, 04-04-2005 03:22:56
3.0 ohm coil or 1.5 ohm coil? Once the silver contact surface has been removed off the points. They will burn in minutes.
JDMAN60
04-04-2005 05:57:56
 Re: 60 Runs bad in reply to buickanddeere, 04-04-2005 05:28:52
The coil I bought is an Accel super stock 42,000 volts at 1.4 ohms resistance. Do I need something different?
buickanddeere
04-04-2005 08:45:15
 Re: 60 Runs bad in reply to JDMAN60, 04-04-2005 05:57:56
A 1.4/1.5 ohm coil needs to run on 6 volts. A ballast resisitor is required to run on a 12V system. The 3.0 ohm 12V coils have twice a smany primary windings to double the primary resistance. The secondaries are identical. What serial number? Did that tractor have bypass starting at one time? Ther eis about 8.0 amps going through the points which are pushed to the limit with the normal 4.0 amps.
JDMAN60
04-04-2005 09:36:27
 Re: 60 Runs bad in reply to buickanddeere, 04-04-2005 08:45:15
The serial # is 6042633 that makes the tractor a 1955 I do not know about bypass starting
buickanddeere
04-04-2005 18:59:29
 Re: 60 Runs bad in reply to JDMAN60, 04-04-2005 09:36:27
I can't seem to find ballast info in the parts CD? The 70 gas was given a bypass starting part way through production. However the 60 seems to be a plain boring 12V system ? Yet the Electrical book SM-2029 on page 80-5-13 shows a bypass starting system for all 50,60,70,520,620 & 720 gas and all-fuel tractors??? The 60 did get the high output generator at # 6030000 I don't mean to be critical but the time & $$$ spent on that Mega coil intended for 9000rpm V8's. Will not mean beans to a 1125 rpm two cylinder. A stock coil is lots. That huge yellow Accel just draws attention and may get you tossed from the stock class. A Pertronics module and a new distributor bushing # 1917207, new solid wires and 3116 plugs are plenty. I'll have to re-read the instructions but some of those electronic systems require an old style resistor core wire from the coil to distributor.
JDMAN60
04-05-2005 03:36:04
 Re: 60 Runs bad in reply to buickanddeere, 04-04-2005 18:59:29
Well you are correct I picked up a stock coil and new points last night and now she runs like a top. I got it out of the shop and drove it around last night and I am very pleased. Thanks for all your help. Jdman60
buickanddeere
04-05-2005 07:05:48
 Re: 60 Runs bad in reply to JDMAN60, 04-05-2005 03:36:04
If the battery's + post is connected to ground, the coil's + post must go to the distributor to get "grounded". If the battery's - post is connected to ground, the coil's - post must go to the distributor to get "grounded".
Ben.So.Tex
04-04-2005 04:10:52
I had the same problem, I put a inline resitor and that fixed the problem for me..Your old coil could of had a built in resistor..good luck Ben
JDMAN60
04-04-2005 05:59:33
 Re: 60 Runs bad in reply to Ben.So.Tex, 04-04-2005 04:10:52
Ben, where did you put the resistor? I assume in the line from the switch to the coil.
old
04-04-2005 08:25:05
 Re: 60 Runs bad in reply to JDMAN60, 04-04-2005 05:59:33
Go to an auto parts store and ask for a ballast resistor for say a 68 dodge dart and put that in the wire from the switch to the coil and you will probably have no more point problems
