Hand Clutch Pivot Bolt Removal
Kevin L.
04-03-2005 22:05:44
Need help with the removal of the pivot bolt for the hand clutch. The bolt is a shoulder bolt under the hand clutch, looks likes it has splines through the housing with the big nut holding the pto enable petal on the other side. have used a hammer and a brass rod but looking for some help in something other than a bigger hammer. thanks
Mike Aylward
04-04-2005 11:00:12
 Re: Hand Clutch Pivot Bolt Removal in reply to Kevin L., 04-03-2005 22:05:44
Kevin, as some of the posters here have mentioned I do make a puller that works very well for those clutch lever pivot bolts. My puller is a heavy duty unit and does not come with all-thread but with heavy duty special bolts. My email is open if I can be of service to you. Mike
F-I-T
04-03-2005 22:12:27
Kevin:
You can try a large c-clamp and a deep socket. Or, you can try to find Mike Aylward who posts here from time to time. He sells a pretty nice puller (or pusher) tool that will jack that bolt right out of there.
I would avoid banging on the ear of that casting. There have been many broken off over the years. It's a sure fire way to get that bad feeling in the pit of your stomach.
Frank
Pat Browning
04-04-2005 03:55:15
 Re: Hand Clutch Pivot Bolt Removal in reply to F-I-T, 04-03-2005 22:12:27
Roger that! Those decades-old castings are just so hard -- and were brittle to start with, made of high-carbon steel; built to last -- but not to stand up to major shock.
Frank -- you mentioned Mike Aylward -- Does (or did) that gentleman live in Illinois? If so, I read a piece in the Chicago Tribune about him some time back during a visit up to see the folk. Anyway, I too would like to see his contraption. And I very well may design one of my own. (PatB)
Mike M
04-04-2005 05:24:37
 Re: Hand Clutch Pivot Bolt Removal in reply to Pat Browning, 04-04-2005 03:55:15
Pat; It is a very simple device made from 2 flat steel plates and 2 pieces of all thread. One plate has a large hole in the center for the bolt head to pass through. The center of the other plate is solid to push against the threaded end. 2 other holes at the ends of each plate for the all thread to pass through. You sandwich this over the bolt and draw up the nuts on the all thread which then pushes out the bolt.Maybe if I get my camera back from loan I'll post a picture with sizes. I have one that we made a copy of from what I think was a boughten one.
Pat Browning
04-04-2005 07:41:27
 Re: Hand Clutch Pivot Bolt Removal in reply to Mike M, 04-04-2005 05:24:37
Thanks Mike -- I saw an ad along with a writeup once in the Chicago Tribune, but wasn't in need at the time so I let it slide. I apreciate your descriptions - sounds simple enough. (PatB)
Kevin L.
04-04-2005 06:57:32
got the concept, now need to know what size all thread and what rough sizes of the metal pieces.
