720 stuck engine/remove block w/pistons HELP
Ben.So.Tex
04-03-2005 18:26:39
I got a 720lp awhile back and have been soaking the engine for 4 months..I started tearing it down today. One of the journals kassel nuts is at the bottom of the crank case and I cannot get a wrench on it. HOW can I get it loose or off? I got all the other off. Engine is still stuck an I want to pull block with pistons. Ben
JDBert
04-04-2005 07:07:36
 Re: 720 stuck engine/remove block w/pistons HELP in reply to Ben.So.Tex, 04-03-2005 18:26:39
You might want to loosen the crank mains as well, I have a 70 gas that the crank is also stuck there. If you force the crank to move you could take the chance of marking up the mains as well.
Mike M
04-04-2005 12:44:36
 Re: 720 stuck engine/remove block w/pistons HELP in reply to JDBert, 04-04-2005 07:07:36
Those tractors both use non adjustable bushing type mains. You can't loosen them, may be a good idea to try to squirt some oil in and around them first.
Mike M
04-04-2005 03:33:31
If you have the others off just start removeing the block assembly,that will let the crank rotate so you can get at the last nut.
johndeeregene
04-03-2005 18:40:49
how about removing the oil pump an goin up through the hole where it is located. can you get at them there. johndeeregene
