45 4620
fredy
04-03-2005 10:56:41
what is the difference in a 4520 and 4620 engine besides the aftercooler. i notice the fuel pump is up front. is one better than the other?
msb
04-03-2005 11:58:03
 Re: 45 4620 in reply to fredy, 04-03-2005 10:56:41
4520 injection pump drives off the camshaft gear.The 4620 injection pump drives off the cam gear itself and is a not subject to wearing the camshaft gear out like the 4520 sometimes did.The 4620 also uses a 4 roller injection pump verses a 2 roller pump used on th 4520.Not so sure that is much of an advantage unless you are a tractor puller.The 4620 went back to the Roosa Master DB style pump .The 4520 ,if it hasn't been converted, used the little CB model pump that parts are no longer available for.Go with the 4620 for a more dependable tractor.
buickanddeere
04-03-2005 11:30:21
4620 aircleaner is much improved.
