Which fuel for the buck ?
Richard E.
04-03-2005 09:41:01
I had a discussion with my Uncle the other day, he said that it didn"t make any difference if you owned a gas or diesel tractor now. The diesel fuel was more expensive than gas, so there was no savings. I say the diesels are more fuel efficient and get more horsepower per hour, so there is a savings. It"s a catch "22" now ? Who is closer to being right ?
buckeye al
04-04-2005 15:15:14
 Re: Which fuel for the buck ? in reply to Richard E., 04-03-2005 09:41:01
I know two cousins that each the same winter bought a brand new Oliver 1755 Over Under Hydraul shift tractor. For one it was his first Diesel tractor. The other stayed with gasoline. They were both pulling 4 bottom 16" trailer plows. While it certainly is possible that one plow pulled easier than the other (they were different brand plows), one may have been better "set up" than the other and the soils may have also been different (they farmed within two miles of each other) HOWEVER.... When the two cousins started talking, the one with the gas tractor found out the diesel was using about 2/3rds as many gallons of fuel per day. They agreed to experiment & traded tractors for a while just to compare. By July, the gas tractor was back at the dealership and had been replaced by a 1755 DIESEL. I realize by today's standards I'm talking of old technology and that will make a difference. I know I'm not answering the quesion but I still thought this true life story might be interesting. Conclude what you want from it but he never went back for his traded off gas tractor!
which name can I use
04-03-2005 19:11:12
Used to be true,but those days are long gone as the price of fuel and and emissions have all changed ,now the initial cost ,repair cost,and emissions have made the cost efectiveness of diesels non issue.With the exceptions of engineering failures Diesels will last longer.
Mike M
04-03-2005 18:16:49
I once saw a chart in an old book that compared gas and diesel comsumtion. At light loads and idle the diesel was far better but as the load increased the difference narrowed to near the same.
old
04-03-2005 09:46:01
Most diesels will do more work per gallion of fuel but also cost more to fix when something brakes. Now days its almost 50/50 but a diesel will probably save a few $$ over a years time but not much
