Flywheel wrench
old hank
04-03-2005 09:12:13
What type wrench do I need to tighten the flywheel in my A, and where might I get one?
36BinMN
04-04-2005 07:47:13
 Re: Flywheel wrench in reply to old hank, 04-03-2005 09:12:13
third party image
This is the size of mine for the A. Hope it helps.
Pat Browning
04-03-2005 19:59:51
e-mail me if you are interested -- either in a genuine JD "A" flyweel wrench, or a design picture for a homemade job. (PatB)
[email protected]
buickanddeere
04-03-2005 11:33:24
A short bar of steel, two sockets welded to it and a torque wrench good for 400ft lbs. Torque with the adaptor at 90 degrees from the torque wrench. Use new grade eight bolts, hardened washers and tall hardened nuts.
RalphinWI
04-03-2005 09:24:16
Many people describe them as S-shaped, I would say it is crank-shaped with about a 3" off-set. It has approximately 1 1/8 six point socket on one end and the same size hex (male) on the other end. Both are in line with the wrench shaft. This was to be used with what is often called a wheel wrench, c.a. 18" long with a 12 point box end on each end. They are frequently found on E-Bay or this board. Approximate cost $50+ and $10
