Is a 4020 a better tractor than a 4320.
Lenny
04-03-2005 04:10:03
Can someone tell me the history between the 4020 and the 4320. I will be using the tractor to move round bales. I hear the 4020 is one of the better tractors JD has made. Both tractors are in the same condition and are the same price.
Glen in TX
04-03-2005 12:42:53
 Re: Is a 4020 a better tractor than a 4320. in reply to Lenny, 04-03-2005 04:10:03
Ran both of them a lot and would go with a 4320 any day over a 4020. Depends on what you have planned for it. If loader duty the 4020 would be the choice because it is a little shorter. You can get a 4020 with power shift too but 4320s never had that. If you're going to do some real work the 4320 can handle it. Was the most trouble free JD we ever had.
msb
04-03-2005 12:20:41
Used to have both.Still have the 1967 4020.It is more nimble and responsive I think ,plus it is a shorter wheelbase.If the 4020 is a side console then it would definitely be my choice.If not the 4320 has a lot going for it,over the older style 4020,12 volt system with alternator for two reasons.
PJBROWN
04-03-2005 04:54:04
I would go with the 4320....it's turbo charged....the 4020 is not. I think the 4320 uses less fuel also.
tony from sw ohio
04-03-2005 09:18:28
 Re: Is a 4020 a better tractor than a 4320. in reply to PJBROWN, 04-03-2005 04:54:04
i wood go whit the 4020 for what you are wanting to do i have 3 4020s 1 4320 and 4430 i like the 4020s the best they handle beter then the 4320 or 4430 and not as hard on fuel tony
