4240 power shift
Dean K
04-02-2005 22:10:12
Howdy JD men,
I have a 4240 8 spd p/s. Had to have JD dealer rebuild p/s completly. Tractor shifts very hard and shifting from 5 to 4 with clutch in tractor jerks to almost complete stop before rolling on. They tell me this is normal on this series tractor. Do you have any knowledge on this matter?
msb
04-03-2005 12:40:46
 Re: 4240 power shift in reply to Dean K, 04-02-2005 22:10:12
4th to 5th should be about as smooth as any shift.The first 6 gears of a Deere 8 speed power shift transmission are underdriven(geared down).Shifting into 7th results in the transmission locking up and is a direct drive from the engine to the differential.In a 4020 that means the engine has to start spinning an additional 147 pounds of transmission weight.So shifting into 7th results in a slower shift response as compared to all other shifts.8th speed is an overdrive.The early twenty series have a rate of shift valve that can be adjusted to make shifting easier in some cases,depending upon drawbar load.If I remember correctly Deere did away with the adjustable shift speed valve in 1969 production models. If your tractor shift is real jerky in the gears you describe,I would expect you might have a sticky accumulator in the shift valve housing.
DouglasW
04-03-2005 09:06:22
Dean,
My 4240 is pretty smooth shifting until you go from 7 to 8 and then acts like it jumps 2 gears. From what I have heard and drove others with this powershift, most jump hard from 7-8 but not any other gears.
twopop
04-03-2005 07:05:58
I have never been around a 4240,yet i dont think your deere dealer knows how to adjust the trans.deere put the first p/s in the 4010 in 1960.i would think that after close to 20 years they would have the jerking fixed
CMB
04-03-2005 07:46:37
 Re: 4240 power shift in reply to twopop, 04-03-2005 07:05:58
Actually JD never sold the 4010 with a power shift. It was introduced in the 3020/4020 in the fall of 1963 as a '64 model. I do agree,however, none of the 4020s with power shift that I have driven, shifted "properly/correctly" in my opinion. All were pretty jerky,& sometimes almost killed the engine on certain shifts. Acted like they were in two gears at once. I've always assumed this was due to improper shift valve adjustment.
