48 model A - electrical
JE
02-19-2004 21:42:31
I have a 1948 model AW with a magneto. I'm looking for a wiring diagram for the lights. Were the lights 6v or 12? My tractor doesn't have the original wiring or any switches. Thanks
Clooney
02-20-2004 06:25:29
 Re: 48 model A - electrical in reply to JE, 02-19-2004 21:42:31
JE, your "A" was 12 volts from the factory [2- 6 volt batteries in series]..
~On the lights & light wire schematics? There are a few different wire prints for that AW.. It depends on whether or not it has a mag [yours does], whether or not it has a cut-out relay or a voltage regulator [we have to know that].. I presume you have 2 front lights & a rear light?
~If your tractor has a cut-out relay it will take a special headlight switch with a resistor on it. If it has a voltage regulator it can use about any available off/on type switch..
~If you send me an E-Mail [put 48 AW in the subject line] & tell me if it has a cut-out relay [2 terminals & an oblong cover] or a voltage regulator [3 or 4 terminals & a square cover] & how may lights it has & where, I will then E-Mail you a proper wire diagram for your particular AW tractor..
[email protected]
John T (More Info)
02-20-2004 06:21:08
JE, Since my post I looked at my diagrams and my literature shows SN 584,000 and up (yours a 1948 was after that SN) as 12 volt and originally many had two 6 volt batteries in series and, therefore, to answer your question, used 12 volt lights. HOWEVER, many got changed over the years and you may just have a single 12 volt battery versus the two. Also regardless how they came out, many had generator/charging system or other modifications over the years. REGARDLESS, I can help you with any wiring or electrical issues you may have.
Does yours have a 12 volt battery now or a 6?? Does yours have only one battery??
Again, e mail me and I will send you a diagram and you can call me ay 812-824-4608 to save us both some typing time.
Lemme know
John T [email protected]
John T
02-20-2004 05:38:36
JE, E Mail me with your return e mail address and the tractor Model and Serial Number etc. I will send you a wirign diagram. Include or post back any specific questions or any wiring or electrical problems, and we can get you going.
Good Luck n God Bless ya
