JD 3010 water in oil
MaverickM23
04-02-2005 14:19:16
I have a JD 3010 gas that has recently started leaking water into the oil. I checked the oil and its a slate gray color. I opened the drain plug and water mixed with oil came out. Also the oil smells strongly of gas. I was thinking that the head gasket was blown but I'm not sure if there may be something else wrong with it. Thanks.
MaverickM23
04-02-2005 15:56:53
 Re: JD 3010 water in oil in reply to MaverickM23, 04-02-2005 14:19:16
Once I found the water in the oil I stopped using it. I had pulled the hood though, and when it ran it was blowing coolant out right beside the thermostat housing. Whats the best way to pressurize the cooling system? And how do you find out if the bearings have gone bad. This was always a good running tractor and I hope to have it fixed for this summer. Thanks
MSM
04-02-2005 15:02:27
Real good possibility the liner seals have disintegrated or the liners have rusted through,especially if you use straight water,or don't change the antifreeze.If you are running antifreeze and it is in the crankcase,DON'T run the engine.Antifreeze will corrode the bearings and then you will more problems than you do now. Pull the pan and pressurize the cooling system and look for coolant running down the inside of the liners,or coming from around the outer edge of the liners next to the block.If it is a leaking head gasket the coolant would show bubbles when running,and possibly blow whiteish smoke.
MaverickM23
04-02-2005 15:58:09
 Re: JD 3010 water in oil in reply to MSM, 04-02-2005 15:02:27
Once I found the water in the oil I stopped using it. I had pulled the hood though, and when it ran it was blowing coolant out right beside the thermostat housing. Whats the best way to pressurize the cooling system? And how do you find out if the bearings have gone bad. This was always a good running tractor and I hope to have it fixed for this summer. Thanks Sorry last post got put in wrong place.
