Loren, While I don't own a D below s/n 109943 (mine is a '38) to confirm the governor action change discussed below, I believe the following information is correct - if not, perhaps an early D owner will correct me. The D carb interchange is a problem (compounded by a misprint in the SM2024 Carb SM table which says the DLTX6 and 16 can be used below 109943). The all-brass DLTX3 was used up to 109943. At that point JD changed the governor and introduced the DLTX6 brass body carb (with a cast iron bowl). That was replaced by the all cast iron DLTX16 at 128100 (Marvel Schebler converted their brass body carbs to cast iron, and added 10 to the part number (DLTX6 to 16, 8 to 18, etc). Then at 161645 JD started using the DLTX63 on the D. The DLTX6,16, and 63 will bolt up and interchange directly, but they will not directly interchange with the DLTX3 for the reason you have noted - the governor action on the rod to the throttle shaft/plate is opposite starting at 109944 - ie, when the governor is trying to close the throttle plate, the plate is opening - and this results in a D sounding like a chain saw engine in a short period of time. What can be done (assuming the throttle shaft is separate from the throttle lever on the top of the shaft - later units are welded together) is to take the throttle lever loose from the top of the throttle shaft, turn the lever upside down, and replace it, but not the screw which attaches it to the throttle shaft. Then rotate the throttle shaft until the throttle plate is closed when the throttle lever hole is back toward the governor and rotating the lever forward opens the throttle plate (like happens on the DLTX3). Then drill a new hole near the top of the throttle shaft and use this for the screw to fasten the lever to the shaft. As you will notice, the throttle plate has a restricted range of motion, but it may be good enough for the carb to function. The reason for turning the throttle lever over - if you don't the throttle plate opens in the wrong direction (the idle holes in the left side of the carb throat are not opened to the manifold). That, with some readjustment of the length of the rod from the governor, should allow the DLTX6,16,and 63 to be used for the DLTX3. But let me add I don't recommend it. Trading your 63 for a 3 would be my choice. Let me know what you find if you check the throttle lever position and if there is an extra hole in the throttle shaft.
