50 running to rich
HalH
04-02-2005 08:00:20
Is the fuel metering screw what I would turn to make the fuel mixture in 50 more lean?
buickanddeere
04-02-2005 09:02:43
 Re: 50 running to rich in reply to HalH, 04-02-2005 08:00:20
Idle rich or while at full rpms and load? What is the float level set at? Tried the engine with the entire oilbath aircleaner canister disconnected?
HalH
04-02-2005 11:40:04
 Re: 50 running to rich in reply to buickanddeere, 04-02-2005 09:02:43
At idle there is some black smoke but clears up. I am not useing the choke any. I can be going along without a load and give it some throttle and that puff of black smoke will come out. With the oil bath off does not make any difference. Do you think it could be to rich with the puffs of black smoke?
buickanddeere
04-02-2005 15:00:29
 Re: 50 running to rich in reply to HalH, 04-02-2005 11:40:04
When idling the sides & bottom of a cold intake manifold is coated with raw liquid gasoline. When a sudden rush of air occurs when the throttle is opened and rpms rise. That gasoline is swept off the intake manifold/ports and into the engine. There's the too rich puff of smoke when accelerating. Turn the heat valve on the manifold to hot and run the engine at 195F. With the carb properly set. The smoke will pretty much stay away when giving her a snort.
