D magneto
stovepipe
04-02-2005 07:35:21
I have a styled D ser# 146016 (late 1939?). Rather than the Wico X maagneto, mine has an "Edison Splitdorf" Has anyone ever heard of it? I had it checked and was told the magnets are weak, so I need to figure out if belongs on my tractor before I do anything. Thanks, Stovepipe
Bob Hollander
04-02-2005 11:28:46
 Re: D magneto in reply to stovepipe, 04-02-2005 07:35:21
I have several magnetos for unstyled John Deere tractors. (Fairbanks-Morse and Edison Splitorf) I have a friend, who lives in Omaha, Ne, that restores my magnetos for me. They look brand new when he is finished. He also tests them on a computer and tunes them to optimal performance. I have never had a problem with the magnetos that he has restored. E-mail me if you would like his name and phone number.
Duane Larson
04-02-2005 07:59:07
Stovepipe,
Your magneto, if it is an Edison Splitdorf CD Spec 0010, is the correct magneto for your tractor. They are a fine magneto, and have more internal adjustments than most to allow "tuning" to get the best possible spark.
The magnet on yours is probably a chromium-nickel alloy and can use recharging occasionally. However, BE SURE whoever charges the magnets removes the impulse unit prior to charging. If that is not done, the latch dogs will become magnetized and not drop out properly as the rpm increases (and the impulse action is no longer required).
stovepipe
04-02-2005 09:14:37
 Re: D magneto in reply to Duane Larson, 04-02-2005 07:59:07
Duane, thanks for the info. I'm glad to find that my D has the right mag(it is spec 0010). My JD dealer knows absolutely nothing about it and everyone told me Wico X was the right mag. Do you know where I can learn more about the Edison Splitdorf? Where can I get parts? My points are well worn, and I'm missing one of the thread-in inserts which holds the spark plug wires into the mag. Thanks for the help.
Donny-B
04-04-2005 19:05:45
 Re: D magneto in reply to stovepipe, 04-02-2005 09:14:37
The Edison Splitdorf mag parts are hard to find as the company has been out of business for years. Some mag shops will re-wind the coils, make the condensors, and solder new carbide contacts on old breaker sets. Check around. These are good working mags.
stovepipe
04-06-2005 20:32:52
 Re: D magneto in reply to Donny-B, 04-04-2005 19:05:45
I found a Mag shop 1 hour away that can fix my edison-splitdorf and get any new parts I need. Thanks for the help everyone.
CMB
04-02-2005 07:54:46
I believe the Edison Splitdorf CD mag was original equipment on that age of "D". They aparently weren't all that satisfactory as many have been replaced with Wico mags. The Wico's are much easier & cheaper to maintain,& I'm of the opinion also much more reliable. I do have a working Edison Splitdorf on the shelf,& if I ever restore my '47 "D" I'll use that mag "for show", but as a using tractor it will be equipped with a Wico XH.
stovepipe
04-02-2005 09:00:25
 Re: D magneto in reply to CMB, 04-02-2005 07:54:46
Thanks for the advice, it's much appreciated. Stovepipe
