JD 60 tach/hour meter instal
Mattf-8
04-02-2005 06:50:47
Hello,
I am looking to put a tach/hour/speed meter on my dad's 1954 JD 60. I have the govenor adapter plate, mounting bracket and tach cable. I am looking for a tach if anyone has one available. Also, are there any pitfalls I should be looking for? Any help is greatly appreciated!
Matt
Mike M
04-03-2005 05:14:48
 Re: JD 60 tach/hour meter instal in reply to Mattf-8, 04-02-2005 06:50:47
I also think that you will need a special governor shaft made with a tach drive in the end.
Mattf-8
04-03-2005 17:08:20
 Re: JD 60 tach/hour meter instal in reply to Mike M, 04-03-2005 05:14:48
Mike,
Thanks, thats what I was figuring. The serial number of the tractor puts it right at the cut off for the earlier style govenor shaft. Not sure I want to get into ripping apart a good working govenor.
Thanks
JD hauler
04-02-2005 19:11:18
check on ebay, they have new ones from time to time, pricey but nice, used is good if it has low hours, other than that, if it has alot of hours, it will surely give trouble if it sat out much, if you are restoring, I would go for new and be done with it.
