620 john deere
tom mattingly
04-02-2005 05:23:09
taking a lot of oil to fill engine after total rebuild. where is it going? every time i run it i lose it on the stick. no leaks no smoke ,runs great.started with 8 qts like the book said.now have 14 qts in her.
BushogPapa
04-02-2005 17:42:26
 Re: 620 john deere in reply to tom mattingly, 04-02-2005 05:23:09
If the Rt hand crankshaft seal is leaking, the oil goes into the 1st reduction gear area, then to the transmission....
Check to see if the transmission is now Over-full..!!!! You have to remove the entire clutch and 1st reduction cover, and gear, to get to that seal...
Ron..
Hoosier JD
04-02-2005 06:08:59
Check rear-end fluid...Dad had a 50 do the same thing, it was ending up in the rear-end. Just a possibility. Good luck, Mike
john vb
04-02-2005 05:59:32
Check all other fluid levels including radiator. It has to end up somewhere.
