40 model john deere trans . noise
Robert T.
04-01-2005 20:36:06
A lot of third gear noise, replaced input shaft and gears all tight and good, other first sp. cluster had alot of play bearings gone.bottom cluster on output seems tight. the sliders seem tight the third gear is the looses one , but seems tight enought not to make that much noise???
buickanddeere
04-02-2005 09:05:20
 Re: 40 model john deere trans . noise in reply to Robert T., 04-01-2005 20:36:06
Growl, whine or clunking? Under load, light load, uphill, down hill or coasting? Pto running make any difference? Gears an origional pair or mix & match?
robert t
04-02-2005 13:53:25
 Re: 40 model john deere trans . noise in reply to buickanddeere, 04-02-2005 09:05:20
Whine, underload and uphill,pto does not mater, gears same teeth
buickanddeere
04-02-2005 15:03:10
 Re: 40 model john deere trans . noise in reply to robert t, 04-02-2005 13:53:25
If there are no metal filings showing up in the trans oil. Then just drive and enjoy. It's the nature of the beast being a well worn,49+ year old tractor with straight cut gears that was usually driven in 3rd gear.
