6030 Muffler or straight pipe
wondering
04-01-2005 17:35:48
Since it's already turbo charged does it matter? It's alot quieter with a straight pipe that the old 4010 with a straight pipe (I'll be finding a muffler for that one now - having read the post below)
billyiron
04-01-2005 17:50:47
 Re: 6030 Muffler or straight pipe in reply to wondering, 04-01-2005 17:35:48
probably not, but what about your aspirator for air cleaner,,billy
wondering
04-01-2005 20:22:19
 Re: 6030 Muffler or straight pipe in reply to billyiron, 04-01-2005 17:50:47
Billy, Please describe the aspirator and it's location, I'll know it. What exactly do you mean
Glen in TX
04-02-2005 00:01:26
 Re: 6030 Muffler or straight pipe in reply to wondering, 04-01-2005 20:22:19
6030 originally came with a aspirator type air cleaner on stack with hose going to aspirator extension pipe on muffler. Yours may all be gone? You can make a suction pipe easily for it in a straight pipe too. Aftermarket ones like that have been around for years and still available or you can make your own.
wondering
04-02-2005 06:14:38
 Re: 6030 Muffler or straight pipe in reply to Glen in TX, 04-02-2005 00:01:26
is that what is known as scavenging? Some of the exhaust flows back through. What does this do? Seems to me that it wouldn't be helpful because it's used air. Is it a pressure or fuel thing? Thanks.
Glen in TX
04-02-2005 07:57:36
 Re: 6030 Muffler or straight pipe in reply to wondering, 04-02-2005 06:14:38
The suction from the exhaust helps pull air and dirt out thru the aspirator pipe keeping the air filter somewhat cleaner. No, it's not pushing exhaust into the intake. Had a 6030 with a straight pipe on it from Thomure in Missouri with the aspirator pipe made on it. Its just a pipe cut in half where it goes inside the exhaust and that side is pointing up or out and welded to the pipe. Exhaust flow going by it then pulls a suction on the aspirator air intake pulling out dirt and helping to pull more clean air into intake. The Thomure pipes are 5" and drawn down to 4" with a flare to fit the JD clamp. More flow than just a standard 4" pipe.
billyiron
04-02-2005 06:49:22
more like a vac effect, in the muffler theres a venturi chamber,connected to the aspirator on top of air cleaner pipe,dirt particles are spun outward in the aspirator then sucked out the exhaustpipe,,thats about as good as I can explain it,,,billy
