Canadian 2240???
mikeinWA
04-01-2005 12:33:51
Found a loader tractor for sale that may work well as a tiller tractor on the vegetables. It is a JD from Canada, has a different number but I cant remember what. Seller says it is the equivalent of an American 2240. Decent tractor, 4000+ hr on gauge. Is what he says true? Why the different numbers? Will parts match? Any thing in particular to watch out for on this model? Thanks for tyhe help!
Mike
Ray
04-01-2005 19:58:17
 Re: Canadian 2240??? in reply to mikeinWA, 04-01-2005 12:33:51
I"ve looked at these also,but was told by 2
different dealers that they couldn"t get parts
for these because they don"t have parts info
for the canadian sold models.Some parts will
interchange but not all and they didn"t know
antyhing about them.I"ve had a hard enough time
trying to get parts for an industrial JD sold int he US let alone something not supposed to be here.
buickanddeere
04-01-2005 21:05:38
 Re: Canadian 2240??? in reply to Ray, 04-01-2005 19:58:17
Your dealer is either ignorant of the facts or is telling you a story. That dealer may even have something on his lot he would rather you purchase. Instead of a tractor from some other vender.
buickanddeere
04-01-2005 14:12:28
Because the US is not the Center of the Universe. There are other larger tractor markets. Partway through the 40 series production, all utility tractors were built in Mannheim Germany with engines from Saran France. To this day most owners still think utility 40,50 55 and 6000,6010 & 6020 are US built. Canada's economy was crippled by Liberal spending particularly from the 1960's onwards. The Canadian dollar was about par when the 10,20,30 & 40 series tractors were built. For the last 20 years the Canadian Peso has been worth 63 to 80 cents US. Tractor, auto & truck jockeys have been hauling cheap to purchase Canadian equipment into the US by the tractor trailer load. Want to get a deer caught in the head lights look? Ask for 510,710,2120,2130,3130,1640,1840 parts at a US parts counter. Mother Deere has those parts in stock here and in the US the same or next day if you have the parts numbers. Call 1-800-522-7448 for the operators, service and parts manual. Dip the coolant with a ph test strip. If acidic the sleeves maybe cavitating through due to lack of maintaince. Pull the trans oil filter and check for any fine shinny flecks. Every now and again some "illiterate know it all tinkerer"will dump SAE 90 gear oil in the transmission. Gear oil totally wrecks the wet clutch packs in the pto, high-low shift and the wet brakes. Check the clutch for sticking too. 90% of owner/operators are unaware they clutch will fail if not lubed/serviced.
Pete/ME
04-02-2005 03:09:15
 Re: Canadian 2240??? in reply to buickanddeere, 04-01-2005 14:12:28
Where do you lube the clutch? Do you mean the grease fitting on the throw-out bearing behind the round sm cover on the tractor left side of the bell housing?
buickanddeere
04-02-2005 09:11:00
 Re: Canadian 2240??? in reply to Pete/ME, 04-02-2005 03:09:15
Yup, one of the best kept secrets out there. Most are as dry as a frazel. Then lubed with about 30 strokes when the clutch begins to stick. Then the operators manual is dug out. Or after the dealer is asked.
mikein WA
04-01-2005 17:23:02
Thanks for the info. Looks like I might trade off my small loader tractor with implements and a bit of cash. Local dealer claims there are no problems with parts match ups etc. I had heard that alot of these tractors where made in Germany just needed confirmation on that from someone withiut a vested interest.
Mike
