4020 Transmission/Kicking out of 4th gear
Glen Anderson
04-01-2005 08:31:30
Occasionaly our '72 4020's transmission will kick out of 4th gear while under load. I'm assuming this means tearing into the trans. to repair. I was wondering if anyone has had any luck with the shifting linkage being out of adjustment or perhaps faulty or damaged detent/springs causing this problem.
Any info would be appreciated!
Jim in AK
04-01-2005 08:50:59
 Re: 4020 Transmission/Kicking out of 4th gear in reply to Glen Anderson, 04-01-2005 08:31:30
Glen,
Which of the two trany dose it have?
Jim
Glen Anderson
04-01-2005 09:04:22
 Re: 4020 Transmission/Kicking out of 4th gear in reply to Jim in AK, 04-01-2005 08:50:59
The syncro range. Sorry.
Jim in AK
04-01-2005 10:25:22
 Re: 4020 Transmission/Kicking out of 4th gear in reply to Glen Anderson, 04-01-2005 09:04:22
I have a 4010 syncro. After a rebuild I had Low 1 and low reverse that would jump out at times. I adjusted the linkage and that took care of the problem. Get yourself a 4000 Series Service Manual. John Deere Tractor Works (SM-2039). Its worth every penny.
Jim in AK
Gerald J.
04-01-2005 20:04:49
 Re: 4020 Transmission/Kicking out of 4th gear in reply to Jim in AK, 04-01-2005 10:25:22
SM 2039 is the manual for 4010 and early 4020 before 1969. The manual number is a TM with mostly different content for the late (like '72) 4020.
Gerald J.
Glen Anderson
04-01-2005 13:36:23
Thanx for the reply Jim. Could I bother you to give me a quick run down on the linkage set-up? Just the high points. I've got an IT shop manual but sometimes a little advise from someone who has "been there, done that" helps out big time.
Thanx
Glen
