3020 with 158 Loader
Kevin Duncan
03-31-2005 20:20:26
Can any tell me if they have every put a 158 loader on a 3020? I was told that you could not do it.
Mike Aylward
04-02-2005 11:44:24
 Re: 3020 with 158 Loader in reply to Kevin Duncan, 03-31-2005 20:20:26
Kevin, while the loader will physically fit it is not recommended for a 3020. I have a 158 mounted on a 4020 and the tip of the bucket to the front wheels is almost the same as the wheelbase of the tractor. The 158 is a very long loader which is where it gets it's increased loading height. Not only would it probably be very hard on your 3020 it would likely not be safe, either. With that much leverage out front your tractor would be unstable with much of a load in the bucket. Hope this helps. Mike
3020
04-02-2005 10:50:16
If you use the loader to capacity, you will destroy the 3020. First you will break the front end off, then if you beef up the front end, then you will bust the frame rails.
TBSCOTT
04-01-2005 04:58:46
I agree w/msn...a better loader would be 48 or 148. I have a 72 3020 w/a 48 loader and its a perfect fit for that size tractor. The 3020 is a stout little tractor but I don't care what color a tractor is, you put on a big loader and you'll break the tractor in half. good luck.
Mike M
04-01-2005 04:53:43
That is an awfully big loader and too long also for a 3020. I would consider a 4020 as the smallest tractor you should put one on.
MSM
04-01-2005 04:15:21
The 158 will fit,but you may have to cut off some material at the rear end of the frame brackets as it should be used on a 6 cylinder tractor. Another thing to look out for is the loader will extend alot past the front of the tractor. It will put alot of strain on the front end and might be alittle unhandy if moving bales or loading manure(tractor light in the rear).That much loader will put alot of strain on the engine mounting bosses on the front of the engine block also,a weak link on 3020's used for heavy loader work.
