oil preesure line
josh anderson
03-31-2005 15:25:23
I was wondering if any one can tell me were you hook up the oil pressure line from the oil pressure gauge on a 57 jd 520 gas. I cant find any openigs for it or anything. thanks
Mike M
03-31-2005 16:48:01
 Re: oil preesure line in reply to josh anderson, 03-31-2005 15:25:23
From the gauge down to the fuel bowl should be a tee there then down to the top of the main case behind the governor housing. Those later 2 cyl.'s used an oil pressure activated fuel shut off to help keep the gas out of the cylinders when shut off.
Dan in Ohio
03-31-2005 16:41:22
Josh, if the original oil line is still attached to the gage just stretch it out and see where it will reach. I have seen oil gages disconnected because the fitting may have leaked where they go into the crank case. Once they start to leak you usually have to get new connectors as they have probably been over tightened at some time.
Dup
03-31-2005 15:43:54
Look on the lower back of the governor housing.
