JD 70
RONNIE PERRY
03-31-2005 05:43:00
I HAVE A JOHN DEERE 70 ON PROPANE TRACTOR RUNS GREAT BUT PTO CLUTCHES ARE SLIPPING I CALLED JOHN DEERE AND THE CLUTCHES ARE 330.00 I WOULD LIKE TO KNOW IF SOMEONE MAKES AFTERMARKET CLUTCHES
Markus
04-02-2005 15:10:02
 Re: JD 70 in reply to RONNIE PERRY, 03-31-2005 05:43:00
I have a JD 70 that I am parting out...just getting to the clutch....if you are interested in used parts...I would sell my used clutch pack/shaft/bearings etc.
Please call if interested...(614)595-2074
Or email: [email protected]
Alex Bertens
03-31-2005 07:59:46
 [email protected] in reply to RONNIE PERRY, 03-31-2005 05:43:00
JD 8300, after the coupling shaft from engine to the tranny failed at the spline during a field work, we followed the manual instruction to unblock the brakes. so we hauled the tractor and reapired.
We reverse the procedure and we unblocked the brake pulling the ball with a magnetic piece. It is still standind like a stubborn donkey.any help please?
thanks Alex
donmyeil
03-31-2005 06:50:55
check the oil in there often as transmission oil is too thick and will cause the clutch to slip and take the faceings off. if there is trans oil in there you need to replace the pto clutch oil pump seal.
Chuck McDonald
03-31-2005 06:24:50
I just got done rebuilding the live clutches in a 50. I am afraid you will have to bite the bullet on this one as I am generally sure no one makes these clutches other than Deere.
Also, expect to replace the brake plate, bearings etc. when you get in there!
I ended up with $500 in mine when it was all done! Worth it though to be able to run my #30 combine with it!
Chuck
dcotton
03-31-2005 06:55:06
 Re: JD 70 in reply to Chuck McDonald, 03-31-2005 06:24:50
chuck, i also have a 70 gas that i am planning on using with my 30 combine.. have you used yours yet?
dennis
