730D question
Maurice Skoch
03-30-2005 22:51:02
The pony start is smoking bad. Has anyone converted one to an electric start? If so, what will I need to do it right?
buickanddeere
03-31-2005 14:26:40
 Re: 730D question in reply to Maurice Skoch, 03-30-2005 22:51:02
Change the cranking engine oil to 40 weight and make certain it doesn't get dilluted with gasoline again. Clean and rebuild the fuel system from tank, hose , shut off valve and carb. Then set the carb float level, mian and idle circuits on spec. Then shut off the engine according to the operator's manual. There is likely one or two cylinders missfiring. Replace plugs with Autolite 216 or 273. Check that each pair is firing together. Has the water pump seal failed and letting coolant into the cranking engine oil? You can check and do all these checks and repairs for the cost of batteries alone of an electric conversion. Each cylinder head's valve train has one oil drain back to the crankcase. After 45+ years many are plugged. The engine will draw lube oil past the valve guides and smoke.
