JD 1840 Tractor
Deerly Parted
03-30-2005 19:18:34
A friend has been looking for a 50-75HP Diesel utility tractor. He found an 1840 JD (60 HP diesel) with a loader. He thinks it is a foreign made tractor that is equivalent to US made 2040's. Can anyone verify this info? Were these good quality, dependable tractors or trouble? What about parts availability or are they interchangeable with the 2040? Thanks in advance.
Indydirtfarmer
03-31-2005 05:15:14
 Re: JD 1840 Tractor in reply to Deerly Parted, 03-30-2005 19:18:34
60 HP would match up with the 2440, and before that, the 2030. Both were/are good tractors. The 1840 was manufactured in Mannhiem Germany, if memeory is correct. The 2030, and EARLY 2440s were produced in Dubuque Iowa, but the last half of the 2440 production run was Mannhiem also.
Indydirtfarmer
03-31-2005 05:23:06
 Re: JD 1840 Tractor in reply to Indydirtfarmer, 03-31-2005 05:15:14
Just got a little info.... The 1640 has a 239 cu, in engine, (like the US released 2550), so I'm guessing the 1840 would(MIGHT) have the 239 TURBO, like the 2750
Still a good tractor....
leon
03-31-2005 03:39:52
The 1840 was made in Mannheim, Germany, with a Saran, France engine, as were the 40 Series utilioty tractors marketed in the US. I'd guess you'd find about 95% parts commonality.
Tech 7
03-30-2005 19:43:26
The 1840 and its predecessor the 1830 were marketed here in Canada for several years under John Deere"s world-wide tractor banner. I believe them to be similar to models built and sold in the U.S. They are very well liked here in Canada and have proven quite dependable. Parts are easy to come by with most available overnight or 2nd day. If you have any other questions put up another post. Bob
