G block boring question
doug vose
02-19-2004 19:27:43
We are in the process of rebuilding our ole G, and the cylinders are worn out pretty good. It has already been bored to 0.090, is it possible to bore it any farther for a normal working farm tractor? We use it normally four to five days a week, if not more. Would it be worth it to bore it any more, or should we look for a new block? thank you,
doug
G-MAN
02-20-2004 10:38:13
 Re: G block boring question in reply to doug vose, 02-19-2004 19:27:43
.125 over aluminum high-compression pistons are readily available, and cost little or no more than the .045/.090 units. Mine were in the neighborhood of $425 with new pins and rings a couple of years ago. Unless you really use the heck out of the old girl, I doubt you'll ever wear it out again, so I'd go with the .125s. There is a small displacment gain, and it would be a shame to see another good "G" block not used if there's another life left in it. In 10 or 15 years, blocks that will clean up at .125 will probably be like gold, because people have been gobbling up the standard blocks and ones that will clean up at .045" for so many years.
Tony M
02-21-2004 22:37:46
 Re: Re: G block boring question in reply to G-MAN, 02-20-2004 10:38:13
Who can I buy new .125 pistons from. I am working on a model A. Can you get forged aluminum pistons?, or stainless valves? thanks tony.
Jack Hollon
02-20-2004 04:56:30
If you need a good G block, I have one. It is bored 45 over, comes with pistons, rings, and pins. Jack
johndeere_john
02-20-2004 03:01:08
I just put my G back together with a .125 over bore and with a new raditor it stays much cooler than with the old type. Watching the temp gauge is always a good idea. Remember they run best at 190 degrees. Jon
John
02-19-2004 20:13:46
Another way out is to sleeve the block then bore it to original or .090 to save buying new pistons.
Its a common practice in automotive repair. Call some auto machine shops with your blocks internal and external dimensions and see if they can accomodate you. Maybe check the archives on this site as this situation has been encountered before.
Roger
02-19-2004 20:00:51
I think you can go to .125 over.
Anderson
02-19-2004 20:00:14
You could bore it out to .095 or even .125, but then you have to find the pistons for it which probably would not be cheap. I would probably look around for a good used block.
