50 air cleaner
Trump
03-30-2005 15:40:09
The oil bath cup on my 50 has sprung a leak. Are new repro cups available? And if so from who? Patching it will be my second choice.
Randy G.
03-30-2005 16:06:44
 Re: 50 air cleaner in reply to Trump, 03-30-2005 15:40:09
I would patch it from the inside and smooth and paint it from the outside. I"ve never seen anyone pull an oil bath cup off a tractor to see if it has been repaired. Much cheaper too!!!
F-I-T
03-30-2005 16:48:11
 Re: 50 air cleaner in reply to Randy G., 03-30-2005 16:06:44
I think Randy has the right idea. I had a small pin hole in my Case VAC A/C cup, and though I probably should have soldered it, I cleaned it well and used some JB weld on the inside. I put a piece of tape on the outside, and the durn thing was so smooth it was tough to see. It has been holding up well against the oil for several months now. It's a cheap try and you are out of very little if it doesn't work. It can be soldered though, and even a patch applied in the form of small steel or brass sheet. A post stamp piece would probably do the trick.
Frank
Trump
03-30-2005 18:30:57
 Re: 50 air cleaner in reply to F-I-T, 03-30-2005 16:48:11
Mine is also pin hole size,only visable when I hold it up to a bright light. But kept finding small amounts of oil and traced it to there. Probably done a little to much sanding and scraping when I was cleaning it up. JB weld would be good, anyway it would be the easiest without having to repaint it. Also a small screw would work,just turn the cup so the screw would be near the tractor center and not visable and not worry about a new oil bath cup unless it decides to spring another leak.
