Clutch handle action
Dave from Texas
03-30-2005 11:55:56
I am working on a 52 A. What is the clutch action suppose to feel like. Is there a snap, does it stay disengaged when pulled back?
Mike M
03-30-2005 13:06:13
 Re: Clutch handle action in reply to Dave from Texas, 03-30-2005 11:55:56
It should snap in and out and require 70-80 lbs pull when adjusted correctly to JD's specs. And when disengaged it should stay that way. Don't leave them in gear disengaged too long as it is not good on them or safe. Put in neutral and snap it back in. If yours doesn't snap or is too tight pop off the outer cover and you will see 3 adjusting nuts. Tighten them to make it tighter,loosen makes it looser.
