Educate Me Please
Green John
02-19-2004 18:53:24
What is the difference between the JD syncro and powershift models and how do they work? My friend has a 4020, so how can I tell what it has? It is about a 65 or 66 year.
Jerry Hull
02-19-2004 20:38:41
 Re: Educate Me Please in reply to Green John, 02-19-2004 18:53:24
The power shift transmisson is a lot like an automatic trans. in a car.It does not require you to clutch when shifting the transmisson to the next range. It really helps when you had loose soil and compacted soil while plowing. You could just up shift or down shift and not lose your momentum. You know what happens when you start bogging down in a hard pull and push the clutch in to drop a gear,you just can't downshift as fast as the tractor is bogging down. Farmalls had their version of a power shift, it was called a TA..,Torque amplifier,the difference being that IH could only drop one gear down and one gear up while the Deere could shift between eight gears with out the use of the clutch. Of course you still had to use the clutch to start moving or when stopping on both tractors,the main advantage was shifting under full power on the go.The way you can tell PS from a Syncro is on the shift pattern of the power shift all of the reverse gears are on the left side moving forwords and back while all of the forword gears are on the right The syncro had their pattern starting at the top with first and third forword gears and low reverse in a tri column then you moved down to the next tri column and you had second and fourth forword gears and second gear reverse in that column.The next column had third and sixth and third reverse the next was fourth and seventh and fourth reverse followed by the last two gear changes on the bottom being just the sixth and the eighth with out a reverse. Now you can see that they were skipping a gear of the forward gears in the columns because you could not drop a single gear in a hard pull before falling to far below your torque range of your engine. Thus came the Power Shift to overcome the stalling of the tractor in a hard pull. I hope I explained it well enough to understand the differences. I didn,t mean to take up a whole forum page explaining this ...hope I didn't push anybody off the bottom of the page.
Newgen
02-19-2004 22:03:53
 Re: Re: Educate Me Please in reply to Jerry Hull, 02-19-2004 20:38:41
You have the shift pattern a little mixed up on the syncro-range. The first range had first, third and reverse, the second range had second, fifth and reverse, the third range had fourth and seventh {also a high reverse on the 3010/4010 tractors, but it was locked out on all other models} and the fourth range had sixth and eighth.
will
02-20-2004 08:09:49
 Re: Re: Re: Educate Me Please in reply to Newgen, 02-19-2004 22:03:53
My 4020 also has 3rd reverse, so they must not have locked it out on 20 series. Mine is a 69' model (first year of console)
Jerry Hull
02-19-2004 22:35:41
You sure are right Its hard for me to peck on this keyboard and thinbk at the same time. Hey guys thanks for puttin up with me. See ya all later Ima goin ta bed
Roger
02-19-2004 20:46:48
Jerry, you do not need to use the clutch to start or stop with the powershift, ONLY when hooking up to an implement, in the manual it is called an "inching pedal".
Jerry Hull
02-19-2004 21:17:16
 Re: Re: Re: Educate Me Please in reply to Roger, 02-19-2004 20:46:48
Well I know that you can just pull it all the way back down in nuetral without a clutch. I can pull my syncro out of gear without a clutch, but even you know that you can,t stop either one of the transmisson while still in any one of the gears without the use of a clutch. I didn't want him feeling that the power shift was completely like an automatic transmisson that has a torque converter instead of a clutch. The tractor will not idle in gear and remain motionless without use of the clutch.
Roger
02-19-2004 21:33:22
 Re: Re: Re: Re: Educate Me Please in reply to Jerry Hull, 02-19-2004 21:17:16
I went back & re-read your post, you are right, you have to use the clutch if you leave it in any gear, what I meant was if you move the lever between gears or down to neutral you dont need to use it. My Case 830 with the Case O Matic can be stopped in gear as long as it is not in direct drive.
Jerry Hull
02-19-2004 22:08:28
 Re: Re: Re: Re: Re: Educate Me Please in reply to Roger, 02-19-2004 21:33:22
I never worked much on them Case o matics I guess they got something like a torque converter don't they. I know the ones I drove when I pushed the clutch in it had hardly no resistance in it.I guess it was just moving a hydralic accuator or something down there. Its been a long time ago but if I remember rite that thing was awful jumpy. Its about that 2390 I was working on today That crazy thing Has got The most confusing transmisson I have ever worked on.Now listen to what this one does when you push the clutch in it will squall like an ole coon and then just kill the dang motor. Now Im talkin 150 horse motor runnin wide open an killin it in two seconds before you can get your foot off it. You know what my Case IH man said to do, he said rev er up an throw er in gear and when she got wound out just start hittin the clutch an the brake at the same time and within a few minutes it should fix itself. I thought he was jokin but that feller sure was a genious because after about thirty minutes of a runnin wide open an a killin it and restartin it the dang thing did keep gettin better till it was back like new. I had to call him back an ask how did we fixed it with that method . He told me the dang cluch packs stick in them things and thats the only way to free them. I think I would go back and get some of them IHC transmissons an put em in them Cases. n change the name back to "IH case"
Roger
02-19-2004 20:17:10
When you look at the shift lever on a powershift, park position is at the bottom, when you move the lever up, you either go to the right & ahead to move forward or to the left & ahead to back up 4 speeds reverse, 8 forward. The lever moves in a Y shape track. On a syncro, park is at the top, close to the gauges & I will leave it at that, you will see how it shifts if it is a syncro. The syncro is good for loader use, you can go from forward to reverse faster than a pwrshift, if not a loader tractor I would rather have a pwrshift, you do not need to clutch with a pwrshift unless hooking up to something, where a syncro, you need to clutch all the time. I had a '69 4020 pwrshift & still have a 4440 with pwrshift
Green John
02-21-2004 14:47:34
 Re: Re: Educate Me Please in reply to Roger, 02-19-2004 20:17:10
Thanks for all the comments and follow ups. Ok, so on the syncro, if I want to shift from one gear to another in the same range, do I need to cluch?
