Welding Gear Reduction Cover
KHE 70
03-30-2005 07:52:59
I am trying to restore a 1956 JD 70D and have discovered about a 6 inch crack in the bottom of the gear reduction cover. The cover seems to made out of a different metal. Can this type of metal on these tractors be welded. If anyone has done it, I would like some info such as the type of welding rods used and any other helpful info.
Thanks,
KHE 70
Markus
03-30-2005 12:45:18
 Re: Welding Gear Reduction Cover in reply to KHE 70, 03-30-2005 07:52:59
I have a cover for sale from a 70D..... $75 + shipping.
It should ship via UPS ground.
Mark call me (937)313-2508
F-I-T
03-30-2005 10:49:57
I'm pretty sure the cover is plain old JD cast iron. Nothing special. Those covers seldom break, so you might want to check on a salvage unit, but if not, I have had good luck with "Muggy Weld". A bit pricey, but I have saved several castings.
Frank
Ol Gray A
03-30-2005 18:00:25
 Re: Welding Gear Reduction Cover in reply to F-I-T, 03-30-2005 10:49:57
Velly interesting!!!!!1
Mike M
03-30-2005 10:47:05
I'm sure it can be welded,or brazed as it is cast iron,but there are plenty of 70D in scrap yards and that should not be a real popular part needing replacement so I would say that you should be able find a good used one reasonable.
Ben.So.Tex
03-30-2005 09:28:01
You may have to braze it with a torch and brazing rod. My 2 cents .Good luck Ben
