B Manifold removed.
Scott Old44B
02-19-2004 18:21:41
Several days ago I asked for advise on removing the manifold on my 44 B. Thanks for all the help, applied heat & lots of it before trying to turn out, 3 of 'em came out relatively easy, but one had to twist off. Had about 1/4" left sticking out of the head, then did the weld a washer & nut on to the stud trick, & then twisted that off a little deeper in. Finally got it drilled out with only the use of a few choice words. Thanks again. Scott...
Clooney
02-20-2004 03:49:05
 Re: B Manifold removed. in reply to Scott Old44B, 02-19-2004 18:21:41
Scott, 3 out of 4 isn't bad.. Too bad that 4th had to fight you.. Those manifold studs/bolts can be a pain.
~You're about the second one in less than a week that's had broken manifold stud problems. Tugboat had problems with an "A" a few days ago..
[email protected]
John T
02-19-2004 19:35:31
Congratultions Scott, If I recall correctly, thats the one you e mailed me the good pictures of. Yep, the heat trick I shared works fairly well and Im glad you got 3 out of the 4 studs removed without having to resort to any drilling at all and it sounds like the old weld a washer n nut trick almost got the 4th one out too. By the way, those were clear sharp pics you sent.
John T
