38 Model A Head bolt pattern?
Anthony Detweil
03-29-2005 17:09:55
Does anyone know where I can find the pattern to tighten and torque the head bolts for my Model A? I found the torque specs but need a pattern.
Earl-IL
03-30-2005 07:45:33
 Re: 38 Model A Head bolt pattern? in reply to Anthony Detweiler, 03-29-2005 17:09:55
ANTHONY, Take the torque spec and divide by 3 . Start in the middle of the head and go in a circular around the center head bolt to work the gasket to the outside .Do this on all three settings then let set for several hours and retorque again the final setting again .If you are still getting movement of the nuts watch for weak stud or lead washer is twisting out.Earl In Illinois
