JD 212 LG Rear end whine
Mark R. 37
03-29-2005 17:03:19
I am writing for a friend who recently purchased a JD 212 L&G tractor. Tractor is a 1986 model, 4 speed transmission and has variable speed lever on right hand side. We have noticed in especially 3rd and 4th gears with variable speed fully open so she will go the fastest it has a rather obnoxious whine coming from the transmission. The shaft coming out the right side with the pulley bolted to it has a tiny bit of play but there is " very little" 90 weight gear oil leaking out around the seal. Local JD dealer said these tractors were very common for having a whine to them but this seems to us a bit too much. Any suggestions or comments for repairs or to just get used to the noise would be much appreciated from anyone who knows what we are talking about.
Jim D in Ohio
03-29-2005 19:56:23
 Re: JD 212 LG Rear end whine in reply to Mark R. 37, 03-29-2005 17:03:19
I know what you mean. I just bought my old 216 back this weekend at a local auction. Bought it new in 1982 and hadn"t seen it since. Seems I am 1st and 5th owner. It has the same problem as yours and I believe it is a common thing. Post this question at Weekend Freedom Machines.org for a more accurate answer.
Mark R. 37
03-31-2005 16:58:37
 Re: JD 212 LG Rear end whine in reply to Jim D in Ohio, 03-29-2005 19:56:23
Thanks for the info. I checked out the other website and got some good info. back.
