Hard Starting Warm '50 B
Dean Lydey
03-29-2005 16:11:02
I"m having some greif with my little B. A 1950 that overall treats me very nicely. When cold, I set the choke, move the throttle to about 1/2 open and it starts nicely. I was plowing this evening and stalled the tractor(2 bottom 16"s uphill in 3rd). I couldn"t make this rascal come back to life. I swapped out spark plugs in an attempt to help but to no availe. This has happened in the past but maybe it"s time to expect more from my tractor and attack this problem. Any ideas?
johndeereman
03-30-2005 07:44:36
 Re: Hard Starting Warm '50 B in reply to Dean Lydey, 03-29-2005 16:11:02
thats a common problem with all the bs ive been around when mine stalls hot under a load i open throttle half choke with pet coks open turn over a couple times till you see gas spray out pet coks close choke and crank usually starts after three or four more turns if not open throttle all the way with choke closed and crank hope this helps.
Will P
03-29-2005 21:53:39
The other guys have given good info. I will give you my 2 cents on restarting after stalling the motor. I have to choke the heck out of my B after stalling it. I choke it until she fires. She is hand start and will almost always start on the 2nd compression stroke. Good luck, and have fun.
Will P
BushogPapa
03-29-2005 19:34:20
If that old gal can pull 2-16" uphill in 3rd, it is time to ease up on her..!!! Treat her like a Lady..!!!!
Maybe you should try to re-start with the throttle just cracked open a little..?? Have you tried a new, dry set of plugs after it refuses to start..??
John T
03-29-2005 17:14:04
Dean you could have some fuel/carb problems going on or ignition, I will just touch briefly on a few ignition possibilities. Is it a mag or a distributor???
Classic examples which can cause a weaker spark when hot are faulty coils or condensors or burned ignition points. You might start by inspecting the points for the proper gap and replace them if badly burned or pitted or carboned up. If they look pretty good and still smooth with no pits but only gray oxide coated, you might be get by with a light clean/buff/ polish.
If theres doubt as to the condition of the condensor and you dont have the equipment to test it properly, you might try a new one, but generally speaking I dont replace them unless I know for sure theyre bad, cuz the new one you buy may not be much better or not the correct microfard rating (especially important in mags).
Is the coil running warm but NOT so hot you can barely lay your hand on it (IF you have a distributor instead of a mag)??? Is this a 6 or 12 volt?? Mag or distributor and brand???
When she wont start you might wanna pull the plugs but have them grounded and wires atatched n crank her over to insure both plugs have a good visible blue spark?? If its a weak wimpy barely visible yellow, the mag or distributor may need some attention. Post back your ignition and what the spark looks like for more.
When trying to restart, are you getting gas vapor or black smoke out the stack or what??? WHEN WARM, I begin with no choke and 1/2 or more throttle and if she donT hit pull the choke out just a short while n then back in and look for some light smoke or vapor out the stack indicating shes getting fuel. HOWEVER, if too much black smoke or heavy vapor you may have her flooded, in which case the plugs will be wet and gas fouled and it might help to have a fresh set to try them cuz (especially if a mag) once fouled they can be almost ruined. If theres no smoke ot vapor whatsoever out the stack, I usually try a bit more choke till she smokes some and then unchoke it.
We really need to know what the spark looks like when hot, then try n figure if its an ignition or fuel problem.
John T
