How to remove M Drawbar?
Ken WI
03-29-2005 13:58:02
I sure would like to remove the drawbar on the M. Sure would make it easier to prep the drawbar & final drive housings for painting. Can anyone out there advise me on how it's done? It looks like there is a big pin that slids into a hole in the front of the final drive housing. This is where the drawbar pivots. IT manual does not cover this. Any help is appreciated.
KB
jd51mt
03-30-2005 11:06:56
 Re: How to remove M Drawbar? in reply to Ken WI, 03-29-2005 13:58:02
Ken,
After you have removed the bolt there will be a pin (sleeve) and two bushings. Spray penitating oil in between final drive housing and drawbar, spray inside of pin. Screw a 3/4 bolt into the pin where you removed the bolt. Tap lightly on the end of the bolt to see if it will move the pin, if it does, remove pin and bolt. If the pin still will not come out, you can use a regular puller on the bolt to pull it out.
MIke
jd51mt
03-29-2005 17:14:46
Ken
Lock drawbar latches, remove the safty bolts (if you use them by the lock bracket), remove the lift links (if you have any). Remove the bolts from the front of the drawbar where they mount to the finals (you may have to drive the bushings out carefully). Raise drawbar by hand unlock the drawbar latches lower to floor. Just reverse to put on.
Ken WI
03-29-2005 17:28:46
 Re: How to remove M Drawbar? in reply to jd51mt, 03-29-2005 17:14:46
jd51mt,
Thx for response. Its about those bushings... Would you give more detail re: how to get them out?
KB
