Fuel Bowl on JD A
BB
02-19-2004 18:01:19
I was cleaning my fuel bowl today on my 50 JD A and put every thing back on and cut the fuel on and nothing happened(no fuel) I loosened the nut that tightens against the bowl and fuel began to flow very fast into the bowl. Will these air lock if tightened to much? Also if you run the tractor a while and cut it off and leave the fuel turned on and come back a few minutes later the tractor will not crank. Turn the fuel off and come back the next day and she fires right up. Any Ideas on that one?
BB
Robert
02-20-2004 07:29:41
 Re: Fuel Bowl on JD A in reply to BB, 02-19-2004 18:01:19
Something else that came to mind after reading your post, is that there's a vent on the carburetor that may be partially plugged, causing your "air lock" problem.
old
02-19-2004 19:31:46
Well if I read you right your talking about the sediment bowl as far as flow, if so thats normal put it on and forget it. As far as your other problem it sounds like your float needle doesn't work right, you may have some dirt in the needle seat or a bad float.
