Hydraulics plugs
uoflncolts
03-29-2005 07:44:06
Are these John Deere? I bought them thinking they were but they do not have the holes in the tip like most that I have seen. I did not know how to post a picture so I posted the auction I bought it from. Thanks for any help.
Will P
03-29-2005 16:54:01
 Re: Hydraulics plugs in reply to uoflncolts, 03-29-2005 07:44:06
My 49G has those plugs. My 51G uses the later ones that the other are talking about.
Will P
billde
03-29-2005 12:11:14
Yes these are early powertrol plugs, not sure what years they fit but they are prior to 1950, cause they did away with the clips in 50.
Mike M
03-29-2005 09:10:41
I agree with Ralph; Those are for the early JD power-trol that used a shear washer. Models around 1947,48,49 A,B,G they should fit.
RalphinWI
03-29-2005 08:05:18
I can't tell for sure from the picture but I think what you have is the early version in which a brass shear washer is used to effect the disconnect (plow unhooking). I am a novice, (outside of my inventory of these someplace in the shop), but I think the open end is the "blind" plug for use when the remote cylinder is not being used.
uoflncolts
03-29-2005 08:28:59
 Re: Hydraulics plugs in reply to RalphinWI, 03-29-2005 08:05:18
I have some blank plugs but these seem to be longer and do not have the hole going through the side of the plug. There are openings at each end but not through the side, so I was not sure if these are John Deere. Any ideas?
Thanks
