4010 LP heats up.
dej(JED)
03-29-2005 05:53:47
My 4010 heats up. I have been told that the thermostat is probably sticking. Is that a common
problem on this model? Any opinions would be appreciated.
Jim in AK
03-30-2005 09:32:51
 Re: 4010 LP heats up. in reply to dej(JED), 03-29-2005 05:53:47
Like the others said its probably the T-stat/s. An LP eng. will run hotter if the air fuel is set to rich. and that would explain the hi fuel consumption that was mentioned in the other post.
Jim in AK
txblu
03-29-2005 07:06:41
Easy to check. Just pull it out (on top of the head as I recall) and run it again. Will take longer to do it, but if you have other problems, you will ultimately get back to that high temp.
I had an LP once and have a diesel now. My experience is that an LP just runs hotter than a diesel and overheating can easily be a problem; and all that generated heat is one reason mine got horrible gas mileage..... .and those are 2 of about 10 reasons it is no longer on my lot.
Mark
Gerald J.
03-29-2005 07:06:41
Old thermostats tend to be a problem. There are two in your engine. Up on top. One is probably stuck solid the other opening slightly.
One in my 4020 a couple years ago was opening at 120 so it wasn't warming up. Same cure. TWO new thermostats and gaskets.
Gerald J.
